Fallo control de traccion Error 27
Foro de la kawasaki ZX10R
rsm_1978
Mensaje por rsm_1978 »
Buenas.
Necesito ayuda!!! despues de un accidente destroce la cupula, ram air etc. Al montar la moto y probarla d modo aleatorio se me encieden todos los modos control traccion y se enciende l luz amarilla y roja f1. Al mirar fallo aparece error 27.
Que puede ser???
Bateria cambiada. Gracias
Boris
Re: Fallo control de traccion Error 27
Mensaje por Boris »
17-56 SELF-DIAGNOSIS SYSTEM Front Wheel Rotation Sensor Signal (Service Code 27) (DTC P0500)
Front Wheel Rotation Sensor Signal Inspection
○For ZX1000R, the front wheel rotation sensor sends the signal to the ECU directly.
○For ZX1000S, the front wheel rotation sensor sends the signal to the ECU through the ABS hydraulic unit.
○The ECU uses the front wheel rotation sensor signal for S-KTRC control.
○The service code 27 is detected with the ECU.
•When the service code 27 and following ABS service codes are displayed at the same time, inspect the front wheel rotation sensor. Service Code B42 (see Front Wheel Rotation Sensor Signal Abnormal) Service Code B43 (see Front Wheel Rotation Sensor Wiring Inspection)
•When only service code 27 is displayed, do the following inspection procedures.
•Disconnect: ECU Connectors (see ECU Removal in the Fuel System (DFI) chapter) Front and Rear Wheel Rotation Sensor Lead Connectors ABS Hydraulic Unit Connector (see ABS Hydraulic Unit Removal in the Brakes chapter)
Manual de taller, de capitulo 17-56 a 17-58
Volver a “Kawasaki ZX10R”
